Back in Feb I shut down my weather station for 6 months because I was moving. After shutting it down, I pretty much did a complete refresh: deleted the old data files, reset the registry, cleaned out the web files. I put it back up early in August and things are working fine except for one annoying feature. When I click the dropdown for averages/extremes for the month, it shows all the months that I previously had the weather station going. Of course, the links are dead since the files they refer to don’t exist. How do I get rid of the months from the list that don’t exist?
I believe all of that data is contained in the wdisplay.ini file located in the root folder of your weather display installation (c:\program files\wdisplay). Edit the file with note pad of just delete the file and then you will have to set up WD and your station from the beginning. Either way, copy the file first so you can at least get back to where you started if you don’t like the results.
Craig
remove those files from the webfiles folder to get rif of them from the drop down list
e.g March2007.htm
