When I go onto the graph interval tab under the graph setup screen and select either 3,6, 12,24 hour graph, i would like to have an option to auto scale each graph.
Also, the only 1 graph option that i can select (by right clicking on main screen graph), only stays as auto scale for less than 1 minute. Is there a way to keep it autoscale, if the above isn’t possible.
Brings out the detail a lot better than i thought it would do!
Excellent! Thanks Brian, even the 12 hour graph looks very much in detail!!
Thanks for adding that!
there is one problem though, and that’s with THSW being graphed.
When i untick auto scale, all is fine, but when autoscale is ticked, teh THSW graph goes up to 309.3c a lot, seems strange. But other than that, all is well.
Another feature I’d be interested in seeing on the scale setup is to be able to specify the high humidity value. I live in Las Vegas and the humidity doesn’t get above 40% too often and it rarely rains. I’d rather set the graph to 40% and then change the upper limit on those days when it actually does rain.
