Auto-ranging Axis
WD used to auto-range the temperature scale on the main summary screen graphs, but somewhere along the way, it stopped doing this. I’m using v10.23p. When dew point dips below the min temp, it jumps to the max, that seems like it may be a bug. You can see what I mean at http://www.weather.scorpion-bowl.com . Temperature is almost clipping today, but you can see dew point is screwed up. If you click on ‘Graphs’ then ‘Week’ you can see where temp clipped, thats why I manually adjusted the scales up, as a result, dew point is now bad. Thanks for any help…
Try lowering your bottom temp to ensure the dewpoint doesn’t over-shoot. You need to ensure the scale of the graph can accomodate the temps your station is reporting. As for auto-scale graphs, there should be some threads about it in the forum. I have the worst luck using the search function, but I will have a go and see if I can find the thread and post a link if I find anything.
edit: Here is a thread that describes how to change your settings. http://discourse.weather-watch.com/t/8550
the problem is WD uses the windchill for auto range…I will also make it check the dew point too
i will also soon (when I get home, and catch up, )add option to be auto range complete for all …(as I know Gerhard would like that feature, and others I presume)
currently in Dubai, on the way home, a day lay over here
its 39c here today, humidity gets down to 10% or so,peaks at 50% in the cooler 24oC nights, but that still feels very humid!!
Cheers
Brian
