Are you using a Vantage Pro Plus weather Station?
Please post your URL here.
my Current cloud cover based on the solar sensor
is incorrect, so i would like to check other users.
Cyclone
http://www.koowee.bigpondhosting.com
is there a problem at the low end?
i think i need another threshold, yes?
are you using the maxiumum solar for lat/long ?
then wd will come up with a % reading, and once below the thresholds in the solar setup, the appropriate cloud cover is set
its been working for some time, then
I place a tick next to Set the weather icons in solar setup.
bingo, its working :smiley:
Cheers
Cyclone
I get a poor reading early in the am when the sun isn’t directly on the sensor, so even though it is bright and clear , I get gloomy . I should change that one day. But in winter it will be fine
