Rather than resurrecting an archived post I decided to start a new thread. Seems WD has stopped updating the AQI data from my Davis Airlink on the 18th of Nov. Curious if anyone else has noticed the same thing? Hitting the test button under advanced settings gives:
After I close that box it does appear WD “sees” the data, but not graphing: Lakewood NY (USA) Website with PHP & AJAX - AQI Page
FWIW pwsWD seems to be working fine: Lakewood NY Home Weather Station (wf version)
Looks like WD gets the data direct from the Airlink: at least, this is how it reads my PurpleAir data. Is the local IP address correct?
pwsWD still works because it gets the data from Weatherlink.
You’re right…I was confused…I know pwsWD got it’s data from the server so I mistakenly thought WD worked the same way. The IP should have clued me to that but it went right over my head. Anyways, power cycled the Airlink and it appears WD is once again able to connect. Thanks for making me re-think this issue.
