Scott,
Check out the recent posts under the CWOP header as this may be related(?). I did a test this weekend to send my CWOP data out via my TNC (thanks for the help) and all worked fine. I don’t recall seeing any extra CR in my data string as mentioned in the other posts and it did make it to findu (via rf) but…I only did one quick test. I’m using 10.27z.
Great to see you got it set up on sending the data out on RF.
It makes a great backup for the data should the net fail in your local area. I use a WIFI signal that is 1/2 a mile away at a RV park, been given to me in support of the web site, so at times I will loose the signal but its rare.
I generally think of “APRS” as a term synonymous with “RF path”. I’m finding that to be a poor assumption on my part. I can’t tell so far whether mine is a TNC problem, software quirk, idiot operator or a combination of these as the above thread will explain.
Noting of course that I know nothing about computer languages or programming [other that what I hear from two brothers in that field, under great pain, at social gatherings ] there may be benefit to writing software that treats compilation of a data string for radio broadcast as a default and that subsequently reformats for FTP uploads, rather than the other way around. Perhaps this is already the case but however it works, the W.D. program overall looks great.
Note the top APRS data is from the radio sent side and the bottom is the internet sent side. It is starting here as the send out time is now 2 times what is has been, this long packet gets lost in the radio hops it makes and not always makes it to the findu site.
I have position less string ticked no. I need the position in the string as my TNC is an old one and hasno position taging ability. This I think is where we are getting the problems as the new TNC’S have a place to set the position and also get it from a GPS. The old one just parots what ever WD sends it and I think that the new ones can be setup to do the same, not sure.
The folks with the newer TNC’s could try setting them so they do not send out a position them selves and let WD do it as it works well as long as your house is not moving.
I will go get the newest ver of 10.28. Running 10.27W for now.
I’m the one for whom you removed the CR, and, I’m pretty sure that it was at that point that FIREWX started getting the weather string ocurring twice in the same line, as
Yes, the double string apparently happened after Brian made a change [at my suggestion and a misdirected one at that] that messed with carriage returns. My bad, so he returned the software to the way it was and called it v10.28b.
I tried the “b” version and W2K crashes; will have to try 28c tonite. Reloaded v10.27u instead, and I’m finally delivering via RF after working with N3OBQ about 20 miles away who could watch my data strings digi about while I hack away at the KPC-3 real-time.
