Apparent Temp. in clientraw.txt not same as WD
Hi!
I have noticed that for the new clientraw.txt file you are producing, the Apparent Temp. value is higher in the clientraw.txt file than what you display in WD.
Are there 2 different calculations going on for Apparent Temp?
An example, right now my WD shows an AT of 90.7, while the clientraw.txt has it at 95.7.
Actually, the temp that is placed into the clientraw.txt file appears to always be 5 degrees higher than what you have in WD.
Any ideas?
