I have noticed an error with the data going from wd meteotemplate, I loaded the api viewer plug-in
It showing up the following problems
Wet leaf sensor is not picking up any data (using a hobby board soil moisture module, wet leaf sensor is on number 2)
Please see image
Soil sensor as an error ( this is using extra temperature sensor number 3)
Please see image
Extra temperature sensor 2 and 8 ,I have no sensors attached
In the weather display one wire viewer there are no roms in extra temperature sensor 2 and 8
In the API viewer Plug-in is showing data?
Thank you
Will upload it now
Good job Brian
I think MT and WD are the only SW which get updates within 5 minutes after a user asks
actually download again, as the change I made was only for Davis users and not 1 wire users
Okay thanks go to download
will take me a couple minutes
mick
Hi guys,
few updates:
[color=red][b]Block Update
What is showing now On the Wet leaf block
Sensor 1
No data as yet
what shows in the new MT show api data for leaf wetness?
This is the link to my API viewer
Just a reminder the new soil moisture wet leaf module is updated with the hb 1 wire reader
From 1 to 3 I have ssoil moisture and number four wet leaf sensor
mick
does leaf wetness show in WD under view, Davis VP extra sensor info
or as a custom tag
The tags I am using are %VPleaf4%
Davis VP extra sensor info graph is showing soil moisture / rain
Davis VP extra sensor info No information regarding the Leaf wetness
The soil temperature sensor is also not showing any information on the Davis VP extra sensor info
Hope this info helps
mick
thank you
so does %VPleaf4% work?
(its not very clear)
then the leaf data should be in the api data sent to MT
I suspect you might not have the latest update of WD still
the raw data sent is in the sentcustomhttpget.txt file
try downloading again a new .zip update
to fix a formating problem with the new leaf data in the api data sent to MT
