Any changes to the way WD reads Novalynx WS-16 CSV data?
My WS-16 data logger has is been configured for a CSV data output sequence of “Date, Time, Rain,Wind Speed, Solar, Barometer, Humidity, Temp, Wind Direction, Dewpoint” for a long time, but I’ve noticed that WD doesn’t read them correctly when I have the “I have Solar” button checked. Seems to switch the temp and humidity readings and will not plot the current solar on the main graphs screen. Uploaded solar data is reading OK on Weather Underground and WeatherCloud, but CWOP station readings show no solar data. I usually also have to select the data rate to 19,200 a couple of times if I need to restart WD for updating etc. Not a big problem as I just check this when restarting.
Thanks as always,
Mike
