Ambient History Data not processing in latest build
Something has happened in the latest build. On my machine that does not run 24/7, it downloads the Ambient history data but does not process it. Graphs, current conditions et al pick up from shutdown time last night even though it downloaded the history data. The download/process window just closes without the data being being run through and the information showing it being processed.
Thanks for all you do and welcome back.
Jim
it could be a too many requests issue I suspect
as I have made no changes
check the raw file, ambientdatahistory.txt
Nope, the file downloaded correctly. I did it a couple times over a couple days. The data file comes in and then the applet shuts down without processing any of the data. 84k of data covering all the right time period.
Jim
best thing is to email me your settings files so I can test/check here
Will do, coming up shortly.
Jim
i tried an older version of WD (from last year) and its not processing the data
and it turns out because the history data downloaded is a day old, i.e its a problem on ambients end by the looks
i have added debug info re the time/date in the history data
Yes, it appears its on their end. I found some reference to it on their facebook group. Mere coincidence that i had a problem concurrent to a new version. Thanks for your time and attention to it.
Jim
Closed - Over 6 months since last post
