Last month, I had a big crash and I lost the sequence of records in alltimerecordsyear, wich only reflect, right now, data received after the crash. Is there any trick I can use to rebuild alltimerecordsyear without having to do it manually?
My rain gauge has a problem with spiders webs causing extremely high rain readings. I store the record gifs at the end of each day so I can look back and correct the data.
