I’m having a real struggle trying to get my all day video created. I followed the FAQ, the webcam files update and appear in the correct folder, but the timestamped images aren’t being created.
I’ve attached my screens, so hopefully someone can see where I went wrong.
And one other thing I noticed is that in the screen “current webcam image/main settings”, it wants me to use a gif image, while in the FAQ it said to load the jpg image, but it won’t even let me choose jpg.
Okay, the videos are being created every hour but they’re only 64 KB and when I try to play them nothing happens (black screen and the time says 00.00).
I noticed something odd in my moviemaker log…
Starting to check for copying file nows to alldayvideo folder
File date =12/30/99 now date 10/08/07
I’ll put up my entire log in case someone can figure out what’s going wrong.
Yes, I installed it a second time to make sure and I’ve doubled checked all of the settings multiple times. I must have read every thread in the forums and I’m basically out of ideas.
I know how you feel Fluffy…I have had problems, and yes I read, and re-read the threads, but they still are not sorted completely, so really cannot advise ‘correct settings’ until I have reviewed mine. Sorry couldn’t be of more help.
Fluffy, for some strange reason your file names do not follow the time of the creation like you have 000330jpgwebcam.jpg created at 9/10/2007 12:02 AM that file should’ve had a file name like 0002jpgwebcam.jpg name. So delete all *.jpg files from your webcam folder and start over again, also do not use the 30 sec. option if you are not capturing at that rate.
Peter
Those files are stamped with the every 30 second filename convention, but saving every minute…that’s exactly what was happening to me…I don’t have that problem anymore…but don’t know how it corrected…
It’s the same dimensions but the image is black because my webcam was in the middle of resetting when it was captured. I have the box checked to “reset regularly” or else my cam freezes.
Yes, I coudn’t find a way around that. I had it set for one minute capture, but the timestamped files were not being created at all. As soon as I checked the 30 sec override, I now have timestamped files, although they’re only captured once per minute. If I uncheck that box I don’t get any files created. I can’t figure it out either.
