A lot of websites shows also the airpressure map from the Atlantic Ocean… I inserted the link to the map in a iframe but getting a error . Connection refused…
Howto fix this
Howto fix this
Your frames.php shows
$show = true;
#$show = false; // remove the # on position 1 if you do not want the atlantic map
# Two maps from the northern hemisphere oceans
# Atlantic Ocean pressure map
if ($show == false) {
$frame = 'baromap';
$frm_ttls[$frame] = 'Atlantic Ocean pressure map'; // name in menu
$frm_src[$frame] = 'https://ocean.weather.gov/A_sfc_full_ocean_color.png';
$frm_type[$frame] = 'img'; // set this to 'img' if you want to display an image only
Try to fix
if ($show == false)
to
if ($show == true)
even with true same error
$show = true;
#$show = false;
if ($show == true) {
$frame = ‘Luchtdruk’;
$frm_ttls[$frame] = ‘Luchtdruk oceaan’; // name in menu
$frm_src[$frame] = ‘https://ocean.weather.gov/A_sfc_full_ocean_color.png’;
$frm_wdth[$frame] = 1280; // optional set this to the width if resizing is to ugly
$frm_hgth[$frame] = 800;
Got it my mistake
thnx
