I have changed the atom-advisory script and the NOAA RSS Top Warning 2.0 PHP Script
I can only assume the weather service made a change and my current script is a problem…when time permits could someone give me some advice on how to correct this issue.
John do you mind pointing me to where the NWS Alert script is located. I can’t seem to locate it the correct script…thanks in advance for your assistance…
While this is not a bad thing if you live on the west coast…but I happen to live on the east coast. Just cannot find the script that is causing this to show???
The Settings.php file has overrides for many of the settings in Ken’s templates. Visit http://saratoga-weather.org/scripts.php if you need directions or file updates.
Update your site using the check-fetch-times.php?show=versions … it will likely fix the issue. Just make sure you update with ALL the files in the distribution from the updates page (directories included).
Well I took the time to update the site…just like Ken explained in his earlier e-mail…do this first before posting…and it also helps to update the NWS-alerts-config file with the correct information.
Keeping up a website is like trying to change a flat tire on a moving car : )
