I can’t even get the first time installation to run.
I’m hosting on Bluehost.
When I go to my www.sitexxx.com/pwsWD/ I get:
Internal Server Error
The server encountered an internal error or misconfiguration and was unable to complete your request.
Please contact the server administrator at [email protected] to inform them of the time this error occurred, and the actions you performed just before this error.
More information about this error may be available in the server error log.
Additionally, a 500 Internal Server Error error was encountered while trying to use an ErrorDocument to handle the request.
What is the URL to your website?
www.sitexxx .com/pwsWD/ seems not to be a real website.
Also the one in your avatar does not respond: http://home.roadrunner.com/~vallone
Nor does roadrunner.com/pwsWD/
The 500 error means there is some sort of typing error or a permissions error.
But without a link to the site, there is not much anyone can do.
www.your_real_website_name .com/pwsWD/_test.php normally returns the cause of a “500 internal server error”
http://www.racineweather.com/pwsWD/
Apologies for the old website link. I’m just getting back into this after a long break away.
Correct website is http://www.racineweather.com
It seems the permissions of your site does not allow php executables.
Even the smallest php script is blocked.
https://www.racineweather.com/pwsWD/startHere.php
Also an invalid link with .php results in the same 500 error , should be a 404 not found error.
https://www.racineweather.com/pwsWD/notexistxxxxxxxxx.php
Maybe it is a wordpress or a “blog” site?
Or does your provider only allows html websites?
Ask your support-person at Bluehost how you have to set your website to run .php scripts.
Text files and images can be displayed without any problem.
https://www.racineweather.com/pwsWD/img/aq_green.svg
https://www.racineweather.com/pwsWD/languages/lang_nl.txt
PHP is now setup.
Installer still returns the same error.
Check my PHP here:
http://www.racineweather.com/info.php
Yes you have PHP
But the .php files are not allowed to run by
your website-setup
or your provider
or your folder permissions
or whatever.
Only your hosting provider support personnel can help you as they can check all things.
If even an invalid URL returns a 500 error it is not anything we ourselves from the outside world can do.
https://www.racineweather.com/pwsWD/notexistxxxxxxxxx.php => 500 error
https://www.racineweather.com/notexistxxxxxxxxx.xyz
Also some of your main-site links run into a 500 error Daily Weather Report => 500 error
Sometimes this occurs when you have a wordpress site in your root folder, as their security scripts are set to block all “unknown” scripts.
Sometimes this occur when scripts are executed from a folder and not from the root.
But all templates will fail if that is set, as all templates need full .php execution acces, also for the folders inside the root folder.
But there can be dozen of other reasons, this kind of problem is a hosting problem, not a template or script problem.
Ask support from your provider,
https://www.racineweather.com/pwsWD/_my_settings/ shows the content of that folder
Parent Directory -
before.txt 2021-06-29 00:39 167
frames.php 2020-11-07 01:28 6.5K
hooks.txt 2020-11-06 09:36 200
imgcurl.php 2021-02-14 01:00 3.5K
iss_popup.php 2020-11-06 09:24 1.7K
languages.txt 2021-06-12 09:42 2.5K
twitter_keys.php 2020-11-06 09:34 848
upload_to.txt 2020-11-06 09:35 1.4K
user_theme.txt 2020-11-06 09:22 962
webfilm_popup.php 2020-11-06 11:42 1.3K
When you click on a link such as before.txt it will correctly display the txt-contents
But every .php file will abort with a 500 error.
The permissions for the folders are incorrect
or .php support is switched off in your cPanel
or similar.
Yes you have PHP
your website-setup
or your provider
or whatever.
Got it sorted out with Bluehost.
Thank you so much for your help!!
