After Upgrade, WD Not Receiving Data [RESOLVED]
Its a couple years old, a Dual core E 6300 @ 2.8 GHZ with 2 GB Ram, fairly fast computer.
with the current version and the history data
what shows under view, WS2010/WS2500 when there is some history data for WD to get
Logger off
Loaded all time records loading the data file month82011.inf Connecting com port Com port connected OK Doing checking of time zone calculation Daylight saving not in use
Current coldest night value (oC) 13.9 06:00 am 21/08/11
Resetting warmest day values 06:01 am 21/08/11
Setting VP time auto daily 06:06 am 21/08/11
setting station type to VP
Logger on
Loaded all time records loading the data file month82011.inf Connecting com port Com port connected OK restarting timer Connecting com port Com port connected OK sending DMPAFT Asking for archived data download Retrieving data from: day 21 month 8 year 2011 Retrieving data from: hour 8 minute 5 ask for time/date of record... 1 6 1 1 1 2 1 0 3 1 0 4 1 0 5 1 118 6 1 180 7 Sending OK... All data downloaded or did not sync correct! Formating downloaded data now into actual data Weather station type number 31 starting get data timer now Doing checking of time zone calculation Daylight saving not in use
thats looks OK…WD sends the aklowledgement back to the data logger
and then at the point the data logger should send the history data
but for some reason its not?
and then it all times out
(before it times out, is the data received light flashing?)
it happens so quick, i leave WD off for 10 minutes, one tic
what shows in the vptemplog.txt file
also make sure the time/date on the davis console matches the pc
0 21 23 78 3 134 2 134 2 134 2 0 0 0 0 149 117 176 1 24 0 157 2 43 64 0 0 255 255 24 0 176 1 24 1 255 255 255 255 255 255 255 255 0 255 255 255 255 255 255 255 255 255 21 23 255 21 23 79 3 135 2 135 2 134 2 0 0 0 0 149 117 180 1 23 0 157 2 44 64 0 0 255 255 24 0 180 1 24 1 255 255 255 255 255 255 255 255 0 255 255 255 255 255 255 255 255 255 21 23 255 21 23 80 3 135 2 135 2 135 2 0 0 0 0 149 117 183 1 24 0 157 2 44 64 0 0 255 255 25 0 183 1 25 1 255 255 255 255 255 255 255 255 0 255 255 255 255 255 255 255 255 255 21 23 255 21 23 81 3 135 2 135 2 135 2 0 0 0 0 149 117 189 1 23 0 157 2 43 63 0 0 255 255 25 0 189 1 25 1 255 255 255 255 255 255 255 255 0 255 255 255 255 255 255 255 255 255 21 23 255 21 23 82 3 135 2 135 2 135 2 0 0 0 0 149 117 192 1 24 0 157 2 44 63 0 0 255 255 26 0 194 1 26 1 255 255 255 255 255 255 255 255 0 255 255 255 255 255 255 255 255 255 255 255 1 21 23 83 3 134 2 134 2 134 2 0 0 0 0 149 117 196 1 23 0 157 2 44 63 0 0 255 255 26 0 196 1 26 1 255 255 255 255 255 255 255 255 0 255 255 255 255 255 255 255 255 255 21 23 255 21 23 84 3 134 2 134 2 134 2 0 0 0 0 149 117 201 1 23 0 157 2 44 64 0 0 255 255 27 0 201 1 27 1 255 255 255 255 255 255 255 255 0 255 255 255 255 255 255 255 255 255 21 23 255 21 23 85 3 134 2 135 2 134 2 0 0 0 0 149 117 206 1 24 0 157 2 44 64 0 0 255 255 27 0 206 1 27 1 255 255 255 255 255 255 255 255 0 255 255 255 255 255 255 255 255 255 21 23 255 21 23 86 3 135 2 135 2 135 2 0 0 0 0 149 117 222 1 23 0 157 2 44 64 0 0 255 255 28 0 222 1 28 1 255 255 255 255 255 255 255 255 0 255 255 255 255 255 255 255 255 255 21 23 255 21 23 87 3 136 2 137 2 135 2 0 0 0 0 149 117 222 1 24 0 157 2 44 63 0 0 255 255 24 0 222 1 24 1 255 255 255 255 255 255 255 255 0 255 255 255 255 255 255 255 255 255 255 255 2 21 23 88 3 137 2 137 2 137 2 0 0 0 0 149 117 238 1 23 0 157 2 44 63 0 0 255 255 28 0 238 1 28 1 255 255 255 255 255 255 255 255 0 255 255 255 255 255 255 255 255 255 255 255
time/date : its at a remote site, i will go for a drive
i start wd,
small data extraction box appears, data is extracted
Data quality is red, then changes green
Data received is red, goes green numbers start climbing, then holds on grey ( while data is extracted)
, then quickly continues
huh, is it working now?, let me reboot
it is working now !! what did i do ??
Shhhhhhh :blush:
maybe the time/date on the console was not correct?
No i checked that a few days back.
The only ‘thing’ is i inchecked then checked (been checked all the time ) the REV B in setup, but not sure that was the fix
no, thats not related
the RevB setting does not affect the history data, only Live data
i think i found the problem, maybe, the issue came back, but when i closed msswchx.exe in task Man. i could connect to the port and WD works
I think the problem is this:
using the On Screen Keyboard and Remote Desktop.
All good now
