advice please on replacing WM-918
Davis stuff seems very exxy.
Any one had any luck with Jaycar stuff?
https://www.jaycar.com.au/wi-fi-wireless-station-with-7-lcd-display/p/XC0422
you get what you pay for
my brother got one of those but its failing after only a few years
yeah, youre probably right
Now looking at OS gear (since my WM918 lasted nearly 20 yrs) . I note that the latest station the WMR89 is much cheaper than the previous one WMR300. Is it better value for money or just a cheaper unit?
One another matter , what are peoples thoughts on stations that have the components all in one unit as opposed to indivudual parts?
cheers
The problem with all-in-one stations is that you are forced to either have the temp/hum/rain part mounted way too high or the anemometer mounted way too low.
Hello Brian,
I bought a wmr89 & it seems to be running OK. One observation though is that there seems to be a fair time lag between what happens on the instruments to when it shows on WD. Is there a delay in the data transmission from the console to WD? My old wm918 seemed much quicker with readings.
the problem is to do with the update rate to the pc
which is not as fast as it was with with the wmr918
are other brands as bad? or was the legendary wm918 the trendsetter here? :smiley:
Davis is much better, at 2.5 seconds for all data :slight_smile:
