i want to plot my temperature/humidity station, unsure what extra temp sensors WD see them as so i click all extra temp’s/humids (except extra 2 - as this is a temp station).
Nothing is plotted - this is on the weather data screen.
With the extra Sensor/Custom data screen of the advanced graphs, i cant seem to get any variables plotted, except i have noticed that when i select a few things from the drop down boxes, then press PLOT, i get a line and what is plotted is extra temp 1 and only extra temp 1, even though this had not been selected, very strange.
Ok, on this screenshot, all i have done is open up the window, selected outside temp (before hand, every dropdown box was set to None), then pressed “last 6 hours”. The result is below.
http://stuartturrell.dyndns.org/weather/files/extrasens1.png
I just tried a few other combinations of plots, button pushes but the result is the same as above, except for this one:-
http://stuartturrell.dyndns.org/weather/files/extrasens2.png
What i done above is closed screen, opened it, selected outside temperature, last 31 days and i get the above graph.
Hope this helps, it has me baffled, which is why i just left well alone, no one else has mentioned it so not that much of a big deal.
With the Weather data screen, when graphing outside temp, extra temp1,3,4, with the relevant humidty, i get this result.
http://stuartturrell.dyndns.org/weather/files/weatherdata1.png
After playing around with the above graph, i can get things plotted, but its a matter of clearing all tick boxes, clicking on a time period, then selecting what data i want to show, though extra temps/humids/wind gust show a dashed black line.
http://stuartturrell.dyndns.org/weather/files/weatherdata2.png
