Is the AcuRite Iris Weather Station with Wireless Wi-Fi station compatible with WD? Or should I get the USB connected model? I’m looking to replace an existing WX station that won’t require any third party s/w to run . I’m currently using an Acurite 5 in 1 station that was destroyed by a tree limb. The display I’m using that does USB to PC running WD without any third party apps is an Acurite 06056RX, it is also in bad shape as the display is starting to fade. So If the Acurite Iris WiFI or USB cabled won’t work with WD direct what will for under $200? Thanks in advance for any help with this…
Jeff
