Hello…maybe I can help out with your 5 day forecast not appearing on your current website, which is here: www.farmingtonweather.com
you need to now your NOAA Forercast download txt, which you said is mnz070.txt
next step is to go into WD/CONTROL PANEL/WEBSITE CONFIGURATIONS/FTP&CONNECTIONS/NOAA FORECAST DOWNLOAD/…Once inside there it should look like this(my setup for it):
http://img246.imageshack.us/my.php?image=sshot33ai2.png
Now for the instructions on how to set your up:
- in the DIRECTORY box where mine says “/data/forecasts/zone/ma/”…change your’s
to this: /data/forecasts/zone/mn/
2 )in the FILE TO DOWNLOAD Box mine says “maz021.txt”…change your’s to this: mnz070.txt
under that box, Click on ADD TO LIST, So that mnz070.txt is now visible in the big box below
now on the left side, for DOWNLOAD TIMES…click on CLEAR ALL, Then click on DOWNLOAD HOURLY
next,…Click on the RED DOWNLOADS OFF, so that it is Green Downloads On
Next Click on SAVE NOW on far right
click on TEST, then after this, exit out of these windows
now go into your WD Folder and there should be a mnz070.txt file inside there… soon your website will get this information, and start displaying the forecast text on your home page and forecast page
(the reason my RED DOWNLOADS OFF is in that screen shot is becasue I am using a different type of forecast and when I took screen shot forgot about this, but yours needs to be GREEN DOWNLOADS ON)
So follow the above directions and everything should start showing up shortly on for your NOAA Forecast on your website.
Please reply back when you have set it up, and if for some reason it doesnt work, we can troubleshoot some more.
The forecast with Icons, that I am using on my webpage here: www.gateway2capecod.com is a bit harder to setup for Novice user’s of WD, So for now start with the easy forecast type for your site, and then you can allways chnage it in future to the advancedforecast2.php type forecast with the icons
one last thing you may want to change within the your forum profile: when I clicked on the globe under your username, it didnt bring me to your farmingtonweather.com site…it brought me to some other crazy site, inwhich I needed to allow some active X control, just to view the page, so if you could edit your forum profile and just add the link to your direct weather website, that would be great. yes…I did see your website in your signature also, which is how I eventually found it.
OK…Let me know how you make out with this, and have a good evening…Chris @ www.gateway2capecod.com
