I note that the 30 day graph only goes back to the first of November. At the end of October the graph was fine. Should it show a full 30 days or only back to the beginning of the month?
mine is ok
it might have been that crash you had phillip, and there is missing/corrupted data?
what does last months data look like under view, graph history (and i have improved that part of the program in 10.19
Yep that is the problem. The October info has gone. :bazooka:
you should be able to get it backā¦if the log file for oct is OK
go:
action, convert wd log files to graphs
but select 92004lg.txt
then click on convert
Thanks Brian, All working again.
