Ver 10.377
Davis Vantage
Windows 8
My records page show the times in 12-hour format which is quite confusing. My Davis Vantage Vue is set to 24-hour. Is there a setting in Weather-Watch to change the time format?
Ver 10.377
Davis Vantage
Windows 8
In Weather Display, go Setup > Universal Setup > Precision/Time/Date/Cloud Height
Thanks, I’ve found that and re-booted. Hopefully it will record correctly from now on.
Do you know how I can edit the existing high and low records on the list? I have tried to alter one entry manually on clientrrawextra.txt but it was later updated to the original value. I assume it is obtaining these data from another file but don’t know which one to amend.
You cannot edit clientraw*.txt files, they are ephemeral.
I am sure you will find an answer if you search the Forum - hint: use advanced search - which is what I would have to do to answer your question
Thanks very much for your reply. I will trawl the forum as you suggest. Best wishes.
