24,48, and 72 hour graphs not showing solar readings? The 24 hour graph is showing it but it doesn’t look quite right. See it at http://weather.ruppworld.com
i was having problems with my web graphs both solar and indoor humidity plots, this i found started with the later version of 10.10j onwards, just had and email from Brian that he had found the reason and to try 10.12. i have now put it on both machines and graphs are ok now, looked at your site not sure why no solar on 48 and 72 hour graphs but new version will correct solar on 24 hour graph ie 0% will now be at bottom.
