On the main WD display, the top of the window contains the version number, registered, station and comm port, current conditions, and then it normally contains 3 buttons for minimizing, rollup and always on top. In this version I am noticing that these buttons appear, then dis-appear, depending on if my mouse is over them or if the window has the focus. If I mouse over the area and the buttons are not there I still get the helper text from the mouse telling me what the button does even though no button is showing…and it still appears the buttons work even if not displayed.
that happens becuase of the weather data that appears on the window title bar, that makes the buttons disappear
its not my fault
but under setup, misc/extra settings, you can now turn off that weather data in that window title bar
but also use a large screen resolution helps too
but otherwise nothing changec in wd to cause this
