Where I can get another copy of 10.13z? I installed 10.14f and the polling is slow again on the wireless. 10.13z was working fine. My bad for upgrading. Thanks
It looks like it may not be registering rain fall either. HW is showing rainfall at present and WD is not. FYI
i actualy speeded it up a bit latetly…it should actualy be better…
i will have another look…
rain…no changes made there…in wd…hummmm
what did the rain amount go up by
except i did make it where you can set the rain adjustment, the modifed rain offset, in the offsets screen (i.e for if you have a larger rain gauge)
maybe thats the problem
check what that number is
it should be 1 by default
re older verison:
its a good idea to make a back up of the current installer you have before downloading the latest one
but i will review the new wireless polling option…
one thing i might have to do is increase the amount allowed (i.e so its not a bad data) for the wireless option, which be transmitting the rain amounts less often (and so the amount of rain increase will be less)
note that wd keeps its own rainfaill totals…separate from the weather station…
oh, yes, but did you have that much rain in 1 hour with 10.13z?
i dont think its a change in version…but its the heavy rain …,.maybe…
or it that allowing the modified rain tip
i have checked that that modified rain gauge number is not zero now in the new 10.14f beta uploading now (in case it was not set to the default of 1)
re older verison:
I have a directory wdisplay\download for the downloaded files and when I download I change the name in the Save As window to include the version eg wdisplay32_1014f.exe. Makes it easy to go back if necessary.
Good idea. I’ve loaded the latest and will keep an eye on it. Hopefully it will rain later this evening. If not, I can always get out the water hose. Thanks for all the help.
It appears to be registering now. FYI… Thanks again.
I’ve got a new problem for you. When I first start the program, it will not poll the station at all. If I go to com port selection and the just hit ok, it starts working fine. Any ideas?
Loaded latest 10.15 and still have to wake it up by activating com port through setup. FYI. All else is working great once the program and station start talking.
