Just wondering if anyone else found that they need to set an offset value for the TAI8570 preasure sensor to get the measurments to look reasonable. I had to add a .6 inch offset :!:
hummm
i though they were factor calibrated,and they have internal calibration, that WD reads and uses, which is based on the sea level pressure reading at the factory setting set…
i should have time soon to get the routine imprived in wd…
