Your Own METAR
I’ve found the options to generate my own metar information, but would like to also create of of the metar graphics, similar to those i create and upload for local airports…
any way of doing this?
Ken
you could use the custom screen to create a metar image
I've found the options to generate my own metar information, but would like to also create of of the metar graphics, similar to those i create and upload for local airports..any way of doing this?
Where’s that option located at? I’ve been trying to figure out the variable %watertempfaren% but can’t seem to locate anything on it, in testtags.php is fall under the US NAVY area. Since I can’t find anything on obtaining information to work with this variable, I figure I probably need to do something like my own Metar as well. Does anyone know how to obtain the water temperature via the US NAVY, to work with WD?
you need to be using a US Navy weather station that records water temperature
Would this be the same as the National Data Buoy Center?
In which data is recorded from buoys in the ocean?
thats something different again
I had a script for this worked out at one time (at least, if we are thinking of the same thing). I am out of town but will see if I can find it this weekend.
