How come when the day changes your yesterdays readings are displayed in the yesterday window and they are not correct and the times have all changed to midnight? THey are all correct while still in the current day window.
yES IT DID WORK THIS PAST DAY… SO IT LOOKS GOOD NOW…
My other issue (which might correct itself after tonight) is that in the NOAA report… the 28th’s data is displayed for day 29…it just skipped over the 28th…
I am having the problem again with the hi low readings …It worked correctly for a day or 2 but now the yesterday readings are all screwed up again…and I am still using the same version that I was using the past few days…(weird)
Also I still have not seen the NOAA style report correct itself… but now it shows info for the 26th, 27th (skips the 28th) the 29th and the 30th…
However the normal style report shows the 26th 27th (skips the 28th) 29th and 2 different readings for the 30th…
