(year).htm
Brian:
I don’t know what others think, but for me it would be very nice to have a (year).htm file, like August2004.htm or September2004.htm, but in this case, reflecting the values for the year.
Thnaks
Cheers
H
should be doable…as i already have a year to date in the view, averages/extreme…i.e , so it would get updated/created at the end of the year :slight_smile:
Yes, Brian, that’s exactly the point, as in averages/extreme the next 1 January another year will begin, being 2004 “lost”. With the file I propose, the whole 2004 will remain in the folder. :smiley:
I would appreciate it a lot
Cheers
H
Hi, Brian:
As we are approaching the end of the year, is it possible to include this feature in a new WD version? It would be very nice.
Cheers
H
uploading a new 10.20i version now that at 5 minute before midnight 31 dec will create and upload , for this year for e.g
2004yearlyreport.htm
in the same format as dailyreport.htm (and as long as you have the dailyreport.htm set to upload (see in the misc settings under view, averages/extreme)
( i will do a test to make sure this works)
Thank you so much Brian. Right now, I really do not need to upload it, as I run my own server, but I don’t know what the future reserves. So, let’s wait for the 31 December.
Cheers
H
Hi, Brian and a Happy New Year for you and your family
I am running 10.20u and 2004yearlyreport.htm wasn’t produced. Is there a way to recover from this?
Cheers
H
Yes unfortunately there was a bug which meant the report did not get produced - Brian noticed that and fixed it - so it should be ok for the end of 2005!
For now though the yearly data can be reproduced by doing view > averages/extreme - then select december 2004 in the calendar and click on the “records to date for the year” button, then you can copy and paste the data that appears into a webpage of your own. This is what I had to do,
Cheers
Ok, thanks, I just returned home from some days out and didn’t have time to see the last posts, so I’m going to do it as you say. For you too, have a nice 2005!
Cheers
H
i like your new weather banner bristolwx :wink:
thanks Brian - yes I redid the custom screen so fingers crossed all should be well with that :slight_smile:
i have noticed a couple of mixed up tags with mine,i guess vossen is fuming over that happening
I will have to have a look at the code to see why that might be happening
