Xml - output and using it
Hi… i would like to use the XML export from WD. I managed to get an xml page up to my webspace once , but never again!!. Secondly how do you use the XML data once its there,
Have read Brians “help” page but unfortunately it didnt.
I have a basic understanding of HTML so i am not a complete dunderhead…
if you use the customise internet and file creation setup, which i recommend, you can set to update (and separately) upload the xml file
then you need to have html code to link to it
see my example here:
http://www.weather-display.com/windy/links.htm
(i.e view the source code to see how i did it)
Hi everyone.
I hate to tell you but people are right when they say that it doesn
I believe the best way to use the xml file is as a means of getting data out of WD. I use it to feed straight into a database and then use that to generate whatever information I want on my website. No worries about cross browser problems and access to just about every bit of data.
Julian
Thanks all - as with all things computing - many ways to skin a cat!
