The few lines that I added to the script should not have cause any problems.
Right now I don’t have any idea what to do next.
- Jim
Hello,
I also do not know what to do, but I just happened to install all the files in the root, instead of a folder
look at the following file test-fc.php
http://meteohila2.esy.es/test-fc.php
and tell me if it looks good at the moment …
I’ll wait for it to update to see if it gives any data …
http://meteohila2.esy.es/fctest.php
Now I need to have a clear path for this file:
Warning: include (/ home / u291478535 / public_html /…/ prognosis mxsim / plaintext-parser.php): error when opening the transmission: No file or directory in /home/u291478535/public_html/fctest.php on line 270
and see if it starts working!
That is wonderful because I was out of ideas about what to do. To me it looks like everything is working correctly. Congratulations.
I see a problem in the test script with determining day/night from the WxSim update time. Please upload the attached to see if I have a good fix. If so, I’ll give you a new comparison script to upload.
fctest.php.txt (17.8 KB)
Hello,
first of all to thank you for all the patience you have lost with me, to inform you that I just uploaded the new file fctest.php
then I indicate the url so you can see the result:
Perfect. Please replace your copy with the attached and you should be good. Set up some crons to run the script in logging mode then sit back and watch.
forecast-compare-include.php.txt (44.3 KB)
Ok, done!!
I’ve already changed the forecast-compare-include.php file to the new one
http://meteohila2.esy.es/forecast-compare-include.php
I have configured 2 crons, one to run at am (after calculating the wxsim) and the other at pm (after calculating the wxsim in the afternoon)
tomorrow as soon as they are executed we will see how it works, and we will observe if we obtain any result
One last query that I do not have clear, to see the script, what template I have to consult the forecast-compare-include. php or the file test-fc.php ??
You would look at test-fc.php. Or if you want, you can make your own page for your site and set it up like test-fc but don’t forget the css or it’ll look bad.
ok Jim,
thank you very much for your great help, without you it would not have been possible to make the script work, thanks !!!
Yesterday, I realized that the forecast script has not been working for a while!
It runs without errors via cronjobs, but all I get, is the weather station’s temperature! According to the log files, it has been working until last February. :?
http://www.meteothes.gr/wxfcastcomp.php?lang=en#
I emptied the log files, to get a more clear view of the results. The scripts are at the latest version released. If there are any Date() errors on page, that happens because some log files are still empty.
The only thing I changed at the server recently, is PHP version from 5.6 to 7.1, a few months ago.
I haven’t found any issues so far, concerning PHP versions… Rolled back to 5.6 temporarily, but no change.
Here’s the content of today’s forecastAM.log file:
1541044800,n/a,~,22,n/a,~,18,n/a,~,22,n/a,~,17,n/a,~,22,n/a,~,16,n/a,~,23,n/a,~,15,n/a,~,22,n/a,~,14,
All other files (testtags, etc) have not changed.
Any ideas how to resolve this?
Thanos
Thanos,
To me it looks like the script is working correctly. It’s logging the WxSim forecast temps, and tomorrow you should see the temps that actually happened at your station. Let’s give it a day or two to see it work.
Thanks Jim, you’re probably right! I’ve checked the scripts many times and they look alright. The next morning forecast will run at 06:15 tomorrow local time, uploaded to the site at 06:30
and the cronjob for the comparison scripts 15 mins later, at 06:45. We’ll find out in a few hours! :roll:
Thanos
I just tried to install this script. I am getting a ton of errors
here are a few when I run https://weatheryyc.com/alt/test-fc.php
Notice: Undefined offset: 1 in C:\Abyss Web Server\htdocs\alt\forecast-compare-include.php on line 683
Notice: Undefined offset: 2 in C:\Abyss Web Server\htdocs\alt\forecast-compare-include.php on line 689
Notice: Undefined offset: 3 in C:\Abyss Web Server\htdocs\alt\forecast-compare-include.php on line 695
Notice: Undefined offset: 4 in C:\Abyss Web Server\htdocs\alt\forecast-compare-include.php on line 683
Notice: Undefined offset: 5 in C:\Abyss Web Server\htdocs\alt\forecast-compare-include.php on line 689
Notice: Undefined offset: 6 in C:\Abyss Web Server\htdocs\alt\forecast-compare-include.php on line 695
Notice: Undefined offset: 7 in C:\Abyss Web Server\htdocs\alt\forecast-compare-include.php on line 683
Notice: Undefined offset: 8 in C:\Abyss Web Server\htdocs\alt\forecast-compare-include.php on line 689
Notice: Undefined offset: 9 in C:\Abyss Web Server\htdocs\alt\forecast-compare-include.php on line 695
This is something I haven’t seen before. Paths to the various files get kind of messy with this script when everything isn’t all in the same folder, and I think that is part of our problem here. Is this /alt/ folder going to be the final destination for this comparison script? I’d hate to do a bunch of mods and then find we need it elsewhere.
Try the attached config where I’ve added some path info that hopefully will work for you.
sorry Jim, I have more errors now
/htdocs is root
/alt is where the template is located as well as all scripts
weather data - ie testtags is uploaded to htdocs/wx_data
I hope this info will help
Aha, we’re on a Microsoft server I see. I modified the attached to indicate that and changed the forward slashes to the backslashes that MS needs. There are two backslashes because the first escapes the second so that it is recognized correctly. I have no way of testing this, but I believe this will get us closer if not all the way there.
fc-config.php.txt (6.78 KB)
no joy with that one
Two more paths to fix and hopefully it will run now with the attached. Note the comment on line 66 for the future if this script needs updating.
If you ever decide to run the script from your root directory as part of your weather site, we’ll need a different setup … similar to the one I use.
forecast-compare-include.php.txt (44.9 KB)
