hi brian
wxnow.txt is not ok i wd 9.99l
carl
hi brian
carl
my mistake, happened with a change with the new control panel added
uploading 9.99m now to fix that
(servers me right for working on wd past midnight)
now it is ok
carl
Excellent Brian !
The control panel really cleans up the setup menu
Thank you
glad you like it
and it means it easier to go between dependent setups
i will add a 2nd one for the graph setup too
I wonder if anything could be done with the “View” drop down, which
currently exceeds my screen height by 8 line items.
I notice that for my station, there are 7 lines shaded out, which I
can not use. Would there be some way to make shaded view line
items disappear off the list if they don’t apply.
I too like how the control panel cleaned up the “Setup” drop down.
I look forward to the panel for graphs.
Herb
the panel for the graph setup is ready in 9.99o
i will do a launch window for the view too, with icons to click
its a good idea
hi brian
the new wd 9.99.p looks Excellent
but in setup / wxnow.txt /use daliy max gust i put in a NO
but it use the max gust 4 the day.
in 9.99o was it ok but not now
carl
ahh,the shifting off the menus scrambled this one a bit
i have fixed now
and the barometer/humidity toggle is a bit mixed up too
i will upload a fix
