Wxnow.txt quit being produced
I’ve done a couple of things here, that may have caused this to start happening. I’ve installed windows XP SP2, upgraded to WD 10.15v, went back to WD 10.15u (To see if that would fix the problem).
My WXNOW.txt file quit being produced, and I’m getting the following error in my WD Error log. The last error just keeps repeating itself every minute. I’ve restarted WD, rebooted the computer, with no luck.
Any Ideas?
ERROR: Error reading TTSfile.ModeName: The value assigned to the ModeName property is invalid at time/date 8:11:00 PM 8/12/2004
ERROR: Access violation at address 0091A163 in module ‘WeatherD.exe’. Read of address 00000364 at time/date 8:12:00 PM 8/12/2004
ERROR: Access violation at address 0091A163 in module ‘WeatherD.exe’. Read of address 00000364 at time/date 8:13:00 PM 8/12/2004
you need to reset the weather voice…
after the changes done to your pc
(i.e control panel, reset, next to the weather voice
and then go into the weather voice setup and either re set up or disable
and then restart wd
Thanks. The reset worked, although it doesn’t make a lot of sense. But, whatever it takes.
I’ve never used the WX Talk, and after doing the reset button, clicking the button to go set it up did nothing. Acted like it wasnt active or anything. So, I just did the reset, and restart of WD. Now creating the wxnow.txt.
I didnt mention in my original msg, but it also was not uploading to Wunderground, and that started working again also, with the reset of WX Talk.
one thing that has come to light:
you need to download and install the British speech driver from the download page as well
