I have set up the Wunderground, however I must have something wrong.
When I log in to wunderground and go to data it says no data available. The internet switch is on and I am able to update Weather Display Live on my web server.
In my experience with these servers like Wunderground and AnythingWeather they do not update as quickly as I would like. I have seen delays of one hour or longer before data I sent is displayed on the sites. I think initial new users may take days for data to show up since it requires intervention on their end…
I can be patient if the wunderground takes a while, however, here is the log file entry.
FTPUPD.EXE started at 8:25:00 AM 8/16/04 agenda items to do…
dowunderground
doupload Files to upload*
Local files: C:\WDISPLAY\webfiles\index.html
Local files: C:\WDISPLAY\formateddata.txt
Remote files: .htm
Remote files: formateddata.txt list of files uploaded*
FTPUPD.EXE finished at 8:25:10 AM 8/16/04
Time taken = 0.05 minutes
Total bytes uploaded = 135 K
Total bytes uploaded for the month = 1150378 K
FTPUPD.EXE started at 8:26:00 AM 8/16/04 agenda items to do…
Remote files: .htm
it should look like this [code:1]actual messages from upload session*
Checking for what else to do…
there are 1 more things to do
Wunderground connected status: OK
Wunderground complete…[/code:1]
I no longer upload my data to wunderground, but I still have it setup. I did a test send and here is the ftp log out put from that transfer:
[code:1]list of files uploaded*
actual messages from upload session* Start Time/date:10:17:41 8/16/2004
caz016.txt
Permanent connection selected
Finshed email agenda
Finished email agenda, no ftp items to do…
[/code:1]
If you do a test send of your data and wait until it is finished, then go to view ftp log and hit the ‘view full log’ button it will only show the last session.
Here is the full log of the manual upload that I did.
list of files uploaded* actual messages from upload session* Start Time/date:1:26:22 PM 8/16/04
In my experience with these servers like Wunderground and AnythingWeather they do not update as quickly as I would like. I have seen delays of one hour or longer before data I sent is displayed on the sites. I think initial new users may take days for data to show up since it requires intervention on their end...
Dan
Are wunderground actually accepting new users??
It just seems like their banner has been stuck on 12092 members for months now!!
I stopped sending my data to Wunderground. For whatever reason they cannot seem to correctly display weather data from WD stations. I gave up on them fixing anything…it doesn’t surprise me that their banner is “stuck” as they probably don’t know how to fix that either
I stopped sending my data to Wunderground. For whatever reason they cannot seem to correctly display weather data from WD stations. I gave up on them fixing anything...it doesn't surprise me that their banner is "stuck" as they probably don't know how to fix that either :)
Interesting. Would you care to elaborate so I can check my data on Wunderground as it seems ok for me.
Weather Underground has always worked for me from day 1. My data is available nearly the minute it’s updated. Now Anything Weather is a different story. It took months for them to get their servers straight and it still runs about 20-30 minutes behind.
[My problems with WU happened late 2003 and early 2004]
I noticed that my individual inputs for hourly rainfall amounts were correct, but the rainfall total was incorrect. Their software was unable to add 0.1 and 0.3 correctly.
I asked John if they could “fix” the rain amount in the db and was told they did not have the ability to fix data in the db. Thats when I decided I didn’t need the headache of dealing with them.
From their pages: Why isn’t my data appearing on the forecast page?
It takes about 1 day for our database to update all of our web servers and place your station on your local forecast page. Also, if we don’t have current data from your station, then we will remove it automatically from the list until we get the next update. Also, make sure you have correctly entered your ID in all capitals. The password is case sensitive too
These are two log entries of mine:
TPUPD.EXE started at 12:40:04 AM 08/17/04 agenda items to do…
dowunderground
do aprs data send
doupload
dogrouped Files to upload*
Local files: C:\wdisplay3\webfiles\gizmo.gif
and actual messages from upload session** Start Time/date:11:50:20 PM 8/17/2004
iaz060.txt
there are 2 more things to do
Aprs data sending now…
APRS Connecting to: 206.97.61.102
Aprs connected
sending pass command
user CW0005 pass -1 vers wx-display 10.15z 31
Sending the aprs data now
APRS data send:
CW0005>APRS,TCPIP*:@180450z4136.40N/09341.73W_354/000g000t066r000p000P
000b10110h88.WD
Disconnecting from the aprs server now
APRS disconnected
Finshed email agenda, and more Internet agenda items to do…
did your log look similar? i would do this, IF you have done everything that you should do, no spaces, code is correctly added, PW is correct (you might want to visit your section on wunderground go to my stations and check that the pw for them and on the section on WD set up are correct. Then if all else fails… send an email to Wunderground
Weather Underground Support [[email protected]] sometimes the problem is on their end and they don’t know it.
ONE additional thought - Firewall, make sure that your fire wall lets the data through. a second thought is you have to let your browser see popups and banners. but do email them for help.
