n9mfk9
March 15, 2008, 11:55pm
1
hi all i need some help
I try to set up the new templates
i can get the wu radar to work ilx is are local nws
I get radar down nomatter what i do
http://98.215.242.116:8080/new/wxradar.php
thanks Beau
ktrue
March 16, 2008, 12:03am
2
Beau,
Please attach a text copy of your Settings.php to a reply, or put the wxindex.php page on your site. I can’t determine what the problem is without seeing how your settings are done.
Ken
n9mfk9
March 16, 2008, 12:37am
3
Hi Ken,
i renamed it index.php
<?php
# A Project of TNET Services, Inc. and Saratoga-Weather.org (WD-USA template set)
# Project: Sample Included Website Design
# Module: Settings.php
# Purpose: Provides the Site Settings Used Throughout the Site
# Authors: Kevin W. Reed
# TNET Services, Inc.
# Copyright: (c) 1992-2007 Copyright TNET Services, Inc.
# This program is free software; you can redistribute it and/or
# modify it under the terms of the GNU General Public License
# as published by the Free Software Foundation; either version 2
# of the License, or (at your option) any later version.
# This program is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
# GNU General Public License for more details.
# You should have received a copy of the GNU General Public License
# along with this program; if not, write to the Free Software
# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA
# This document uses Tab 4 Settings
$SITE = array();
# Automatic Info we might need
$SITE['REMOTE_ADDR'] = $_SERVER['REMOTE_ADDR'];
$SITE['REMOTE_HOST'] = $_SERVER['REMOTE_HOST'];
$SITE['WEBROOT'] = $_SERVER['DOCUMENT_ROOT'];
$SITE['REQURI'] = $_SERVER['REQUEST_URI'];
$SITE['SERVERNAME'] = $_SERVER['SERVER_NAME'];
# Sitewide configuration
$SITE['charset'] = 'ISO-8859-1'; // character set for webpages (iso-8859-1=latin)
$SITE['CSSscreen'] = 'weather-screen-php.css'; // 800px design
$SITE['CSSprint'] = 'weather-print-php.css';
#$SITE['CSSscreen'] = 'weather-screen.css'; // Classic design
#$SITE['CSSprint'] = 'weather-print.css';
# Configurable Carterlake/WD/PHP template Site Settings
$SITE['WXtags'] = 'testtags.php'; // for testtags.php weather variables
$SITE['organ'] = 'USA Weather Website with WD/PHP & AJAX';
$SITE['copyr'] = '© ' . date("Y",time()) . ', Your Weather Website';
$SITE['remote'] = "onclick=\"window.open(this.href,'_blank');return false;\"";
$SITE['tz'] = 'CST6PDT'; //NOTE: this *MUST* be set correctly to
// translate UTC times to your LOCAL time for the displays.
// http://saratoga-weather.org/timezone.txt has the list of timezone names
// pick the one that is closest to your location and put in $ourTZ like:
// $ourTZ = 'America/Los_Angeles'; // or
// $ourTZ = 'Europe/Brussels';
$SITE['location'] = 'Somewhere,Some State, USA';
$SITE['email'] = 'mailto:
[email protected] ';
# Weather Station sensors
$SITE['UV'] = true; // set to false if no UV sensor
$SITE['SOLAR'] = true; // set to false if no Solar sensor
# Station location: latitude, longitude, cityname
$SITE['latitude'] = '37.27153397'; //North=positive, South=negative decimal degrees
$SITE['longitude'] = '-122.02274323'; //East=positive, West=negative decimal degrees
$SITE['cityname'] = 'Saratoga';
# USA Specific settings
$SITE['noaazone'] = 'IlZ051'; // used for NOAA advisories and advforecast2.php forecasts
$SITE['hurlURL'] = "wxadvisory.php"; // page to launch for details on NOAA advisories
#Forecast script settings area
$SITE['UVscript'] = 'get-UV-forecast-inc.php'; // worldwide forecast script for UV Index
// comment out above line to exclude UV forecast
# if you have WXSIM and plaintext-parser.php, set $SITE['WXSIM'] = true;
# to have the WXSIM forecast text appear in the dashboard along with your primary forecast org's
# forecast.
$SITE['WXSIM'] = false; // Set to false if no WXSIM/plaintext-parser.php
$SITE['WXSIMscript'] = 'plaintext-parser.php'; // script for decoding plaintext.txt into icons
# fcsturlNWS is the point-printable forecast URL from http://www.weather.gov/ (used by advforecast2.php)
$SITE['fcsturlNWS'] = 'http://forecast.weather.gov/MapClick.php?CityName=Springfield&state=IL&site=ILX&textField1=39.7814&textField2=-89.6447&TextType=2';
$SITE['fcsticonsdir'] = '../forecast/images/'; // NOAA-style icons for NWS, WU, WXSIM forecast scripts
#---- in the following section, enable settings for ONE primary forecast organization
# pick which script AND org are to be used for your forecast here: (last uncommented pair will
# be the ones used on the wxforecast.php page and in your dashboard and sidebar
$SITE['fcstscript'] = 'advforecast2.php'; // USA-only NWS Forecast script
$SITE['fcstorg'] = 'NWS'; // set to 'NWS' for NOAA NWS
#$SITE['fcstscript'] = 'plaintext-parser.php'; // WXSIM forecast (if only forecast script)
#$SITE['fcstorg'] = 'WXSIM'; // set to 'WXSIM' for WXSIM forecast
# ajax-dashboard, ajax-sidebar settings (will override defaults in
# the scripts themselves when included in this site
$SITE['uomTemp'] = '°F';
$SITE['uomBaro'] = ' inHg';
$SITE['uomWind'] = ' mph';
$SITE['uomRain'] = ' in';
$SITE['uomPerHour'] = '/hr';
$SITE['imagesDir'] = './ajax-images/'; // directory for ajax-images with trailing slash
# note: date format used for PHP parts only. Weather-Display dates are not processed
# except on the astronomy page
$SITE['timeFormat'] = 'D, d-M-Y g:ia T'; // Day, 31-Mar-2006 6:35pm Tz (USA Style)
//$SITE['timeFormat'] = 'm/d/Y g:ia'; // USA format 03/31/2006 14:03
//$SITE['timeFormat'] = 'd/m/Y H:i'; // Euro format 31/03/2006 14:03
//$SITE['timeFormat'] = 'Y-m-d H:i'; // ISO format 2006-03-31 14:03
$SITE['timeOnlyFormat'] = 'g:ia'; // USA format h:mm[am|pm\
#$SITE['timeOnlyFormat'] = 'H:i'; // Euro format hh:mm (hh=00..23);
# carterlake-radar settings (will override defaults in
$SITE['noaaradar'] = 'ilx'; // LAST 3 characters of NOAA Radar Site ID
// e.g. Radar KMUX has $SITE['noaaradar'] = 'MUX';
$SITE['WUregion'] = 'mw'; // Wunderground regional maps
// 'sw'=SouthWest, 'nw'=NorthWest, 'mw'=Midwest
// 'sp'=South Central, 'ne'=North East, 'se'=South East
$SITE['WUname1'] = 'City Level'; // tooltip label for mode=1
$SITE['WUname2'] = 'South SF Bay'; // tooltip label for mode=2
$SITE['WUname3'] = 'SF Bay Area'; // tooltip label for mode=3
$SITE['WUname4'] = 'Southwest US'; // tooltip label for mode=4
$SITE['WUname5'] = 'Entire US'; // tooltip label for mode=5
# GRLevel3 Radar image settings
$SITE['GR3radar'] = 'kmux'; // set to lower-case full name of NEXRAD radar site
$SITE['GR3DIR'] = '/GR3'; // set to directory for GRLevel3 images (or '.' for root directory
$SITE['GR3type'] = 'cr'; // radar image type 'cr','br','cr248','br1' etc.
$SITE['GR3img'] = 'jpg'; // GR3 image type 'jpg' or 'png'
$SITE['GR3cnt'] = 10; // number of images in series 10=(_0 ... _9 in name of file)
$SITE['GR3width'] = 512; // width of GR3 images
$SITE['GR3height'] = 512; // height of GR3 images
$SITE['showradarstatus'] = true; // set to false to suppress 'active' message
# end of configurable settings
# set the Timezone abbreviation automatically based on $SITE['tzname'];
putenv("TZ=".$SITE['tz']);
$SITE['tzname'] = date("T",time());
ktrue
March 16, 2008, 1:30am
4
Beau,
Try capitalizing the radar name last three characters to
$SITE['noaaradar'] = 'ILX';
n9mfk9
March 16, 2008, 1:49am
5
Hi ken that worked are there any other setting i need to set for wu
also do you get the lat a n long from wd also why did you use a file for just the graph data Thanks Beau
ktrue
March 16, 2008, 2:43am
6
Beau,
there are multiple settings you need to do for the WU radar besides putting stuff in Settings.php
The directions for WU-radar setup are at http://saratoga-weather.org/scripts-WUradar.php#WU-radar
I don’t get the lat/long from WD – you’ll need to put that in the Settings.php file in decimal degrees. Those settings are used in several places for the UV forecast, the nearby earthquakes, and the WU-radar to highlight your location on the close-in maps.
I don’t understand what you mean by
why did you use a file for just the graph data – which page are you talking about?
Ken
n9mfk9
March 16, 2008, 2:03pm
7
Hi Ken I was Talking trends-inc.txt why is it its own file
thanks Beau
ktrue
March 16, 2008, 2:31pm
8
Beau,
The majority of the data presented on the trends page is used nowhere else on the site pages so the testtags was used for data that is common to many pages, and the trends-inc used for just that one page.
should be CST6CDT
You are in Central Time zone correct Beau?
