HI
I have just updated WU-forecast.php but cannot get it to work, could someone please have a look at http://www.mangawhaiweather.co.nz/WU-forecast.php
Thank you
HI
Thank you
The problem seems to be that your webserver cannot connect to www.wunderground.com at this time:
Network error: Connection timed out (110)
When the connectivity is restored, your forecast should reappear.
Hi Ken
I tried again and got this error:
Notice: Undefined offset: 1 in /var/www/vhosts/mangawhaiweather.co.nz/httpdocs/WU-forecast.php on line 520
Notice: Undefined offset: 1 in /var/www/vhosts/mangawhaiweather.co.nz/httpdocs/WU-forecast.php on line 521
Notice: Undefined offset: 0 in /var/www/vhosts/mangawhaiweather.co.nz/httpdocs/WU-forecast.php on line 531
Notice: Undefined variable: WUforecasticons in /var/www/vhosts/mangawhaiweather.co.nz/httpdocs/WU-forecast.php on line 764
Warning: Division by zero in /var/www/vhosts/mangawhaiweather.co.nz/httpdocs/WU-forecast.php on line 764
Notice: Undefined variable: WUforecasticon in /var/www/vhosts/mangawhaiweather.co.nz/httpdocs/WU-forecast.php on line 765
Notice: Undefined variable: WUforecasticons in /var/www/vhosts/mangawhaiweather.co.nz/httpdocs/WU-forecast.php on line 770
Notice: Undefined variable: WUforecasttext in /var/www/vhosts/mangawhaiweather.co.nz/httpdocs/WU-forecast.php on line 845
Notice: Undefined variable: PHP_SELF in /var/www/vhosts/mangawhaiweather.co.nz/httpdocs/WU-forecast.php on line 847
Forecast blank? Force Update
WeatherUnderground :
Notice: Undefined variable: WUforecasttitles in /var/www/vhosts/mangawhaiweather.co.nz/httpdocs/WU-forecast.php on line 991
Forecast from WeatherUnderground for .
Hi Tony,
Still the same problem… your webserver is unable to connect to www.wunderground.com. Have your tech support folks at your website hoster diagnose the issue.
When connectivity from your website to wunderground.com is restored, the WU-forecast.php script should again work for your website.
Ken
