Hi everybody,
this is Steve from Switzerland, I just enrolled in this interesting forum hoping to learn what there’s to know about weather in general, weather software and hardware.
I’m writing 'cos I’m having a problem: some time ago I bought a LaCrosse WS2500 which came without pc cable, so I ordered an ELV WS2500 PC radio interface to store data even when absent or when pc off.
I’ve got quite all the software on the market, including Weather Display.
Before buying LaCrosse I had a Oregon Scientific cabled WM918, which did a marvellous work, connected via RS232 to the pc and used Weather Display to store data on pc, creating graphs, statistics and so on. All together worked wonderfully.
Since I’ve bought LaCrosse and the ELV WS2500PC datalogger (version 3.1) I’m not able any more to collect data neither store them on the computer using WD, although in WD advertisement it’s confirmed that WS2500PC datalogger is a supported hardware. First of all I must say it’s not an hardware’s trouble, because with both the delivered evaluation software (PC weather station) and Werner Krenn’s WsWin32, data retrieval from WS2500PC datalogger occurs perfectly every 5 minutes with correct data. WD instead retrieves very slowly and with great difficulties the old data resident on the datalogger when opening the program, in case it does, no current conditions and no extremes values are updated on the main screen and dials (while they are in “Extra daily extreme values” and in the graph). Furthermore at opening not all the data on the datalogger are retrieved, at a certain point WD stops downloading, it seems like it gets stuck, 'cos values doesn’t change any more (even current conditions), I need to exit WD and open it again to see a change… Again the countdown timer on the “WS2500 data logger setup” window gets stuck, every time I access it I find my settings changed to default ones, when I access “Weather station type” window in “Control Panel” in setup menu for the first time after opening WD, I find no weather station is selected (even if on the title bar it’s written WS2500PC) and I have to select it again… It’s an absolute disaster!
It seems to me to have set everything properly, but something important seems not to work, and I couldn’t find what. Hope someone of you has the solution, otherwise WD will be absolutely unusable with LaCrosse and ELV datalogger, and it’s a pity 'cos WD is a very good and complete software…
Technical data:
Weather Station LaCrosse WS2500 (sensor version 1.2)
Datalogger ELV WS2500PC (version 3.1 - update 5 mins - connected via serial cable to COM3 port)
Weather Display v. 10.16g
I repeat: it works correctly with Werner Krenn’s WsWin32 (which is unfortunately the limited version) and the delivered evaluation software (PC Weather Station) which doesn’t have the fundamental (for me) FTP function for uploading on the Internet, neither all the nice graphs and statistics, like WD.
Thank you very much for your help.
