WS2500 Timer on
How do I turn this off, I have a 2010 and in the Data report window it keeps saying
WS2500 timer on
Retrying
WS2500 timer on
Retrying
WS2500 timer on
Retrying
I was trying to setup the remote client viewer over a lan or internet, before this all started to happen :?
Thnks
Sask
you must have set the weather station type as a ws2500
try setting as stationless
and then restart
Tried it, still doing the same thing.
email me the file
wdisplay.ini
from c:\windows or c:\winnt
and i will have a look
I’ve been having the same thing happen to me. It started when I went to version w. It appears as a second window when I start WD. I just check OK an all appears well. I have the station line chosen for the WS2010.
i have fixed the problem with that ws2010/ws2500 window appearing at start up…
in 10.14 , uploading now
that came about after the change in the weather station type setup (its a whole new format)
daveq, what exactlty is reported in that window?
WS2500 timer on
should only appear if you have selected a WS2500 type weather station
if you could email me your settings file, from c:\windows or c:\winnt
i will have a look
This is what appears in the window. I’ll send the files shortly.
Retrying
get data click
Ws2500 timer on
Retrying
get data click
Ws2500 timer on
Retrying
get data click
Ws2500 timer on
[/quote]
