I have Weather Display setup to read straight from the station. This works until it is supposed to be complete then just hangs for about 5 minutes and then starts to work. Unfortunately as an example I just loaded WD and it said taking data from the previous 39 minutes. I then closed and restarted it and it said it was taking data from the previous 42 minutes. Anybody else getting this ? It also reads in the Pressure completely wrong.
at the moment, the direct data extraction is not working properly
the solution is too instead use heavy weather to get the missing data, then export that data to a logfile, then get wd to import that data via the data logger setup screen (but turn off the switch on that screen (see under control panel, data logger setup)
