Ws2010 - no temperature displayed :(
No temp display for last couple of day’s since running last 2 versions of WD :cry:
Probably something I did :?: Any hints on getting temp display back 8O
does it report Ok under the ws2010 data report/setup?
do you have the correct outdoor temperature sensor # to use selected there?
8O the settings look ok to me :cry:
select outdoor sensor to use is set at 6
change that to 1
and you will then be fine and dandy :wink:
(then click on OK)
:smiley: Dang - you were so right - thanks Brian.
