Ws 2510
Sorry to bother you all but I’m having difficulty getting my WS 2510 to work with Weather Display version 10.10r (Please note that I have the trial version … I didn’t want to buy the software until I saw that it worked). I suspect there is probably a simple fix. Let me also mention that I have PC Weather Station also installed on my computer (Windows XP). The following is what I get when I “check status” and “get data” from the WS 2500 data logger setup screen.
getting status
Ws2500 timer on
Ackl, stopping timer
getting status2
Status report arrived
Sensor #1 is OK.
Sensor #2 does not exist.
Sensor #3 does not exist.
Sensor #4 does not exist.
Sensor #5 does not exist.
Sensor #6 does not exist.
Sensor #7 does not exist.
Sensor #8 does not exist.
Sensor #9 is OK.
Rain sensor: is OK.
Wind sensor: is OK.
Brightness sensor: is OK.
Pyranometer sensor: is OK.
Indoor sensor: has an error. :31 %
Without HF
Sensors: 0-9
DCF assync
Battery OK
Interface version 2.4
Interval time 15 minutes
get data click
Ws2500 timer on
getting data
Data length= 44
Block Nr: 198
Block Age: 19
new raw baro 815.0
Requesting data again
setting next data
getting data
No more data available*
I do not get any readings on my Weather Display. Help.
Dick Rohlf
p.s. The following is a small sample of what I get on the Program Error Log.
final_data[1]:=2;
final_data[2]:=1;
final_data[3]:=6;
final_data[4]:=247;
final_data[5]:=3;
final_data[1]:=2;
final_data[2]:=1;
final_data[3]:=6;
final_data[4]:=247;
final_data[5]:=3;
Yes, Please help…I am getting the exact same response.
its the raw baro at 815 hpa that is the problem
set a barometer offset, under setup, control panel, barometer offset and rainfall
of say 180 hpa
as you must live at altitude?
aslo make sure you have set a outdoor sensor number to use under setup, control panel, ws2010 data setup
e.g set as 1
and also use 10.10v, as a few other small fixes with that station type
Thanks for the suggestions. Your right. I live in the Sierra of California at 6000 feet.
Thanks and ditto your right…Denver 6000 feet…
Changed offset…its now working…
Thanks for the great support and speedy response.
