WS 2500 PC and Error Message
i have a WS 2500 PC and new now the WD Software. When I connect the station i only get the message
“Ws2500 timer on”
no data are received??
What is the problem or my mistake?
ok, try the WS2500 staton type instead of the WS2500PC station type
I am getting a Ws2500 station soon, to fix a few things…
also, make sure the correct com port is selected
does the data revieved light flash at all?
i tried to sychronise the clock with the station first and oups it reads the data. I will watch, whats happen after a reboot of the pc with the same setup.
Lets see
http://www.beier-karsten.de/wetter/meinwetter.htm
since 3 days it’s not possible to get data out of my WS2500 PC.
Only the message “Ws2500 timer on” is visible, whatever the station is connected or not.
What can i do, in one or two days the station is full of data an i will lost the comming one.
Karsten
try clicking on get data in the ws2000 data setup window?
(or get time? then get data?)
i will have a ws2500 here in 1 week…
did this happen with aupgrade of wd?
or tyr the latest version?
Hum-In: 44 %
Pressure: 981 hPa *
WindSpeed: 8.1 m/s
WindDirection: 275
ed, you should not be seeing that message, LOL
I will fix (with my rusty old ws2010 data logger i have here, that wont pick up the temp/hum sensor anymore,…)
hee wake up early there
windy weather here 5 - 8 Bft
rain a lot (hmmm what’s a lot)
ok fix it whit that rusty old man
but he’s still going strong ! :smiley:
i tried this more and more but nothing happens. With or without the station on the com port. Also the same message
getting time
Ws2500 timer on
Thanks to read this.
Karsten
a few other things to check:
is the com port number correct?
have you tried the ws2500 PC and or the ws2500 station types?
i will be able to find out whats wrong once the station arrives here (its in the post today from the UK)
:slight_smile:
yes, the com port is correct. I tested the original software an synchronised the DCF with the PC. I tried more than the ws2500PC or the ws2000, also STAIONLESS the same thing.
Ws2500 timer on.
Karsten
as it worked at all, older version of wd?
10.03h same problems!
ws2500 on
and al sensors down oeps 8O
ed, i have not had a chance to look at why the ws2010 is being affected yet
but it will be something i changed in trying to get the 2500 to work better
i just realised there is another thread on the ws2500, with dotty
i made a change, it was working,…but then i missed that thread, and that change i made stopped it working with the ws2500 (which is a bit touchy with a certain timing of commands)
i have instead made a tweak in the other direction whcih might help, in version 10.03i
which will be ready in a few hours
Version i takes no effect. Same place same problem
I tried version 10.01e, it works?!?!?!?!?
I’ll be waiting now for your ok when you have the real station at home to roll out the final version for good working with WS 2500 PC
Karsten
good that version works
I will reset things back to the way it was with that one, from a backup, tomorrow.
The only thing is, that the programm sometimes brings me
getting status
Ws2500 timer on
Ackl, stopping timer
getting status
getting data
with some handy trys it’s getting the data.
For me it works Brian !
V 10.03i
no more ws2500 here ha!
succes ilmweather
thats good ed, i reset things back from a backup
Ilmweather:
does the latest version (10.03i or j (which someone reported had corrupt files), work?
also, Ilmweather, how quickly does the data update on the console?
also, if you click on get data before its ready to get more data, is the data recent>?i.e i am wondering how often i get more data, instead of every 5 minutes or 15 minutes
