My wind gauge on my weather station is not working, and has not been working for the past week. Has anyone had this problem before? I recalibrated the station today, but this did not work.
any ideas
any ideas
maybe the console is not able to pick up the signal, or has lost it…?
does wd pick it up via the separate data logger?
maybe check for spiders in the actual rain gauge,they can stop the tipping mechanism
I usually pull the batteries out of the console, and let it cycle through what sensors it is picking up. Sometimes I will do the battery pull and bring the sensor right in beside the console station if I have to , just to see if the sensor is giving off a signal or not.
If WD is picking up the sensor, then chances are your console is just not getting the signal for the sensor in question (due to positioning).
