I installed V2.1 and it worked until I put my serial # in now it just sits on the configuring??? Any idea’s?
Your web page is still pointing to the clientraw.txt file - http://www.n7xrd.tzo.com/wdisplay/webfiles/clientraw.txt
You must change this to point to the wdlconfig.xml file as described in the readme file.
Julian
Ah geez I knew that!!
Thanks Julian works GREAT!!
Your web page is still pointing to the clientraw.txt file - http://www.n7xrd.tzo.com/wdisplay/webfiles/clientraw.txtYou must change this to point to the wdlconfig.xml file as described in the readme file.
Julian
