WMR968 extra sensor #2 temperature and humidity appear on Setup Extra sensor real time graph as Sensor #5 & #6.
WMR968 extra sensor #1 temperature and humidity appear on Setup Extra sensor real time graph as Sensor #3 & #4. WMR968 extra sensor #3 temperature and humidity appear on Setup Extra sensor real time graph as Sensor #7 & #8 and display properly on the Extra Sensor Real Time Graph.
I have WMR968 extra sensor #3 in use as a solar sensor in a jar.
Tried changing sensors. Any WMR968 extra sensor set as channel 2 fails
are the values always ok on the main screen though?
Not with 10.16 beta on the Extra sensor real time graph. Still have spikes with 10.16 beta.
Looks like 10.16 beta has readings from WMR968 extra sensor #2 (temperature and humidity) reversed with WMR968 extra sensor #3 on the Extra sensor real time graph.
What ever controls the graph plot of the WMR968 extra sensor #2 temperature and humidity (appear on Setup Extra sensor real time graph as Sensor #5 & #6) is resulting in spikes on the extra sensors real time graph.
I have extra sensors 1 & 2 placed side by side on a table inside the house. Extra sensor #3 is in use as a solar sensor in a jar outside in the sun.
Only the graph is corrupt. When the view WMR918/68 extra sensors is selected the readings displayed are proper for each sensor. Extra sensor readings are also correct when displayed on the main screen above the wind speed dial.
