From the top:
Looking for data from 23:19:00 23/01/09
This says that WD believes that it should be looking for data records from 23:19 on 23rd January 2009.
That choice will be based on the value that is in the [Davis download] section of WDISPLAY.INI as WD starts up.
WD updates that figure while it is running, so when it is restarted it can start picking up data from where it left off.
Next, here’s the first data collected from the data logger
**Current actual data D1
**Current actual data D2 31 16 13 17 01 09 00 00 00 00 15 00 CB 00 28 0A 0D 0C 08 0D 0C 0A B0 00 00 20 00 D3 43 D6 33 01 00 C0 00 2B 3C 00 00 01 20 00 51 0A 00 00 36 07
Decoding missed data now
Time from decode 01/23/2009 19:22:00
baro check 982.0
indoor temp check 19.2
indoor hum check 43
missed data time: 19:22 date: 23/1/9
Missed data Acumulate Rain= 51.97
time from data 19:22:00 looking from 23:19:00 current time 08:13:28
number of sensor = 1
Current Channel # =1
missed outdoor temp =3.2
missed outdoor hum =81
The important bit there is that this data was from 19:22, which is before 23:19, thus the data will be ignored.
Similar things continue happening (i.e. data from before 23:19) until here:
**Current actual data D2 31 16 17 17 01 09 00 00 00 00 15 00 CB 00 28 0A 0D 0C 08 05 0C 00 00 00 00 20 00 D2 23 D5 33 01 00 BE 00 2B 3C 00 00 01 17 80 5D 28 80 00 75 07
Time from decode 01/23/2009 23:22:00
baro check 981.0
indoor temp check 19.0
indoor hum check 43
missed data time: 23:22 date: 23/1/9
time from data 23:22:00 looking from 23:19:00 current time 08:13:40
Difference in rain =0.0
missed outdoor temp =-2.3
missed outdoor hum =93
*****updating data 23:22:00 23/01/09
The important bit there is that this data was from 23:22, which is after 23:19, thus the data is relevant. The “*****updating data” bit tells us that WD is saving the data to its records.
Similar things continue happening (i.e. data from after 23:19) until here:
No more missed data, finishing up, WMR200
*** updating data arrived during history data ** 07:53:00
*** updating data arrived during history data ** 07:54:00
*** updating data arrived during history data ** 07:55:00
*** updating data arrived during history data ** 07:56:00
*** updating data arrived during history data ** 07:57:00
*Finished*, updating wmr200 log files
Station ready
No more data is being sent from the datalogger, so WD records ‘live’ data that arrived while data was arriving form the datalogger.
At this point operation changes over to normal collecting of ‘live’ data.
Does that make sense?
Which OS?
Do you by any chance allow the computer to “Hibernate” or “Suspend”?
