Hello i have the wm-918 weather station , how do you set up the rainfall registration in the weather -display programme? Cheers !
setup barometer offset and rainfall
then enter in your starting amounts, click on yes, then click on save settings
if you have inches ticked, then you can enter in the box provided tha actual amount in inches, e.g 0.512
or use the slider to select the amount in mm
