WM 918 Battery Warning Logfile
Is it possible to deactivate that option? Because I do not have any batteries in my Weatherstation Monitor. So I always get a warning message that the batteries are low. And the logfile (wm918battery.txt) grows and grows…
Thx
hi,ok, i just checked, and i will make it so that it only updates if you do not have the warning alarm set for that
i wonder if this has caused problems for others
hummmm
next version will have that changed
Hi Brian
Thx for the info - no it is not a big problem - I only wondered if I can decativate this warning message - because I do not use batteries in my monitor - therefore I know that my “batteries are low” - and I do not need that message.
If you can make that option to deactivate the message possible - that would be great - if not - ok - I can live with that also - then I will delete the logfile per hand.
Thx!
Stephan
this should be ok now in the latest version…? :slight_smile:
Hello Brian
Ok - I have had a look - and the logfile is not anymore there - Thank you for this! Again a very fast update from you!
Stephan
