new update ready now
re having your api key showing…who in the world is actually going to want to use your api key to upload their weather data anyway though ? (as your lat/long and station name is tied to your api key)
Thanks Brian I’ll let you know how its going
Re API key, I know it is unlikely, but I never cease to be amazed at some people’s delight in screwing things up for others.
Thanks Brian alls working OK
Youre right Mark people do it just cause they can
OK heres a question and sorry if I’m a pain
should cronwindy open a new window (which is happening) every time it sends data or should it refresh
also cannot close cronwindy window with the close button :? (have to use the Linux kill switch X)
ah
it should close auto once sent
I will have a look
(I am trying to take a break though as it is easter monday here)
it should close OK…just checked the code…
do you see any error message?
what if you run it from a terminal window?
OK mate sorry to interrupt your Easter have a great day and enjoy yourself
here is the output from a terminal window
(cronwindycom:23335): Gtk-CRITICAL **: gtk_main_quit: assertion ‘main_loops != NULL’ failed
0
Those are gtk graphic library errors
With the updated compiler
But should not cause a problem
Does the program exit after sending the data
That is the Q
No its not exiting after the data is sent
It has to be closed manually, I have set it to send every hour so that there are not as many to close down when I have to
I will investigate later tomorrow and let you know
Thanks, no hurry
it should be OK now
download a new WD linux update
Thanks Brian excellent work
