They look nice… but you should have used Vectors… Then you would be able to rescale them and export the sized you wanted.
BTW… the arrows are backwards. If the bearing is 90
Wind Direction Graphics Generator Script modified to add more options to cardinal directions.
New: you can use xxxx for none, or PnWPdZ for Poland
Hi Kevin, it depends on how you look at it…
Your wind direction outside, it points to where the wind is coming from, not pointing
away from where the wind is coming from… this is what i based it on… Also, this is
actually a compass not a anemometer so the compass is pointing at the direction the
wind is coming from
As for vectoring, i struggled big time to follow the instructions so baled out and when my
own when, this is why it aint too good when very small the smallest readable is about 68px
but not the bearing in the middle, Sorry folks, it was a 1st time try, I will have another go
some time and see if i can follow the instructions better, unless someone else wants to have ago?
see instructions here
I did a little editing to Mikes graphics to change the arrow.
I hope you don’t mind.
Traj
http://trajnet.com/dload/rose.zip
http://trajnet.com/dload/rose2.zip
Rose2 has the “feathers” on the arrow
Michael,
Very cool… I’d not taken a look at that before… looks like a lot of work to put that together.
Of all the wind rose’s that have been posted the most functional and cleanest are your style. Your “tool” is great for those that don’t have the time or the skill to create them. They look good even when very small.
I was looking for a new wind rose for a new template project that I am working on and used your style as the inspiration for the set I built in vector graphics. I just activated them on the test site: TNET Test template
Thanks Kevin. It is really hard to make one that looks good at 58x58 pixels
… almost impossible to make a arrow rotate around one pixel in the center (actually I found it mathematically impossible to do it perfectly with image rotate php code).
I like your windrose set you made.
Here is the set that I am using in two sizes, 58px and 75px in png format with alpha channel transparent.
Included in the zip file is the Xara raw source file for those that want to play with them.
Another set that I actually created a while ago. After I finished exporting them all out, I realized I had messed up and had SE on both sides of the compass instead of SW on the west side… Ticked off so I put it aside.
I’ve just fixed the lettering now and have them ready to be re-exported out again. Will do that later tonight or tomorrow…
Set will include 3 sizes… 58px 75px and 100px and will include the raw Xara source file as well. I was planning on dropping all but the 4 cordinates on the smallest image and making the letters larger on them.
Sample sheet is below:
Finished exporting them
Includes 3 sets sized as 58px, 75px and 100px as well as the Xara raw source file.
Thanks for sharing Kevin … again.
Hi folks
I have just had another play, not sure if this is any better, but the Abode Illustrator template
is available if folks what to have a play to improve it?
Theres 2 types now
Impressive!!
Thanks, only took me all afternoon pmsl… I aint sure if there going to be good enough
when small though? I dont use the dashboard at present so i cannot comment
I put the first one in Xara and in PS and reduced to 58x58 they are not so defined as they are in the dimensions you posted…bummer. Maybe a bolder background color would do the trick?
I like both of the small ones except that the N,S,E,W get swallowed up and the detail is completely lost. I guess that’s why others who have made windroses have just gone with the big letters and very little detail. IDK…I don’t have a lot of imagination when it comes to creating new graphics #-o
Yeah i know what ya saying, I was browsing through the net (as ya do) and came accross the
compass and thought it would be nice as a wind rose…
I will have another play and see what i can come up with, thanks for testing it for me
OK, I now had a play again and this time created something not as ellaborate as the others
this is simple bold digital type, any thoughts?
Yep…that works better even @ 58x58
Thanks, it looks like the bold it is the better it will look when its shrunk down…
I an new to this cant ya tell lol
When you said “N,S,E,W get swallowed up and the detail is completely lost.” above
was you making it smaller, cause i actually made those small ones at your 58x58 so
there was no need to shrink them any more?
